78 280zcar Posted August 30, 2005 Share #1 Posted August 30, 2005 I just recently bought an aftermarket JSK fuel rail. I was wondering if anyone has installed these fuel rails and where they located the fuel pressure regulator and what kinds of things did they use to mount it, it has bolts for mounting it to the stock location but no hardware for mounting it. Is there a way that someone could send me some pics of how they did these two things so I can get some kind of idea on what to do. Thanks in advance. I probably should have posted this in fuel injection but I am a nerd Link to comment https://www.classiczcars.com/topic/17088-need-help-on-fuel-rail/ Share on other sites More sharing options...
hls30.com Posted August 30, 2005 Share #2 Posted August 30, 2005 Juan is helpful with that info too!I bought the brake spacers and hardware,and he instructed me on where to get crossdrilled, vented rotors cheep.I didn't buy the rail, but it stands toreason he would be helpfull.WIll Link to comment https://www.classiczcars.com/topic/17088-need-help-on-fuel-rail/#findComment-136187 Share on other sites More sharing options...
TomoHawk Posted August 30, 2005 Share #3 Posted August 30, 2005 I have a different rail fromPallnet. He includes two pieces of bent aluminum bar to mount the rail to the intake. My pressure regulator is connected to the oppposite end from the inlet, and mounted in the center, about the same location as the oem regulator, for looks. The pressure gauge is next to it.It should not be too difficult to make your own mounts; the injetors and injector hoses should be enough to support the rail by themselves. Link to comment https://www.classiczcars.com/topic/17088-need-help-on-fuel-rail/#findComment-136199 Share on other sites More sharing options...
