Before I Port my Z I will prove it on a 4 cylinder first
Well lets not sit here and bash him, maybe he knows what hes doing?????
yeah, .....and maybe the world is flat, & the sun revolves around the earth. Oh, and the moon is made of green cheese too.
  • 7 months later...
Hi
Found the prob with the plugs ????????
Had to advance the timing by sum 18 Degrees.
Had to add a secondary vac adv switch, made out of an old A/C pressure switch mounted backwards.
some data for those who have the time and understanding.
60 BTDC@6500 light load
30 btdc@6500 wot
48 btdc@3000 light load
18 btdc@3000 wot
24 btdc@1000 light load
6 btdc@1000 wot
hmmm seems to be linear induction until 6500 rpm.......
Graph it you will see......
above 6500 I can push it another 10 degrees.
runs fine now
I hvae raed this tread and N0w I feel lke my grain has gotten aloot dummer. :stupid:
I just wonder what you are smoking? I would guess its the tires from the other cars you have destroyed. Do you grind it all up and put it in a pipe or do you roll it up in some ZigZags? But what ever it is you are smoking you should share it with the rest of us.
