Site Updates this Weekend ×
71datsunZ -
Someone beat you to the control panel. I have really worn out vent emblems, I have side turn signal metal parts, I have the tool box doors, and specifically what window trim (which windows). Also, how many turn signal metal parts do you need?
agemeansnothing -
I have the center consol (but its for an automatic). I also have an oil cap.
- Ian
https://www.classiczcars.com/topic/17146-need-parts/#findComment-137131
Hatch Hinge Rubber "pocket" Seals; Right and Left
(These fit IN the body and over the hinge itself. They usually have a flat metal piece that holds the rubber behind the hinge bolts.)
Headlight Acorn Rubber Mounting pads. Right and Left.
(This is the flat rubber gasket that goes between the "acorn", that is the acorn shaped headlight case, and the headlight support that's on the fender.
Interior Plastic Finishers Any and All
Console (Series II) with Center Fuse Cover.
Hatch Pneudraulic Support Rod.
Ignition, Hatch, Glove Box, Both Door Locks.
Sun Visors, Left and Right.
If you have any of these, let me know what condition they're in and how much you're asking for them.
Enrique
https://www.classiczcars.com/topic/17146-need-parts/#findComment-137133
Well I need a washer bottle, cargo straps, driver side window, fuel pump, fan clutch, fuel line, and a oil cap, center console, let me know what's there. Ian
He's parting out a 240. A lot of those parts you list wouldn't fit your car.
https://www.classiczcars.com/topic/17146-need-parts/#findComment-137153
  • Who's Online   0 Members, 0 Anonymous, 903 Guests (See full list)
