hi, i have questions about:
1- cold start valve
2- air regulator
3- throttle valve switch
1- is it a right way to check the cold start switch by connecting it directly to the battery and listen to it weather it is clicking or not? and how can i check its operation in the system? when should it operate so i can use a voltmeter on its terminal?
2- how to chcek my air regulator? i noticed that it is printed 70 ohms on its socket, i measured it and it was 70, but i connected it to the battery and nothing happened, is it damaged? how to chcek it and how to check wether it is controlled or not..
3- how to adjust the throttle valve switch? and if anybody knows what it its funcion plz tell me, coz I played with its position and nothing happenned, a difference in idle occures when i turned it with a screw driver out of the thottle body, just a slight difference..
https://www.classiczcars.com/topic/17229-checking-componontes/
  • Who's Online   2 Members, 0 Anonymous, 1,371 Guests (See full list)
