what you will get from 1-800-radiator is a piece of junk. Poorly made, won't last like a radiator should. In the long run you'd be wasting money.
If your radiator is still sound (not already ROTTED), follow Ed's advice and have it boiled and rodded. Otherwise, have your local shop RECORE it.
If you insist on an aluminum rad, forget the word cheap.
https://www.classiczcars.com/topic/17297-radiator/#findComment-138501
Just take your radiator and get it redone at a radiator shop....best thing to do--you know where the core came from as well when you do this. I did this for my radiator and my heater core, both are as good as new...had the top cap/bottom cap of the radiator rewelded on (if that's what they do...)
https://www.classiczcars.com/topic/17297-radiator/#findComment-138533
  • Who's Online   0 Members, 0 Anonymous, 328 Guests (See full list)
