Cleaning Control Knobs
You know- those knobs with the cut in letters and graphics like on the windshield washer switch, trip odomoter reset, ilumination reostat...
What kind of cleaning solution works best for you? I ussume you're using a troothbrush to get into the grooves. I like to use the orange cleaner from the dollar store for everything, but havent gotten to try it yet; only used water so far.
Also what wouldn't you use, or what stuff would dissolve the white paint?
thx
https://www.classiczcars.com/topic/17306-cleaning-control-knobs/
i used a very soft bristled toothbrush. soaking the part in a mild dish detergent solution (warm not hot water) for 15 mins to help loosen the crud seemed to really help.
i avoided any harsher cleaners (gojo, formula 409, fantastik, etc) so as not to loosen the bond of the inlaid paint.
i also tried adding a little bleach, very little, to the solution and was quite satisfied with the results.
bart
  • 1 month later...
