If the tires were not rubbing before and they are not a new tires size (larger) then I would suspect the springs are saggy. 10 years could be many life times for a set of spring or they could be like new it all depends on how the car is driven. If it is driven a lot or on bumpy roads or hard then they could be shot. What size tires do you have?
I have Arizona Zcar springs (http://www.arizonazcar.com/springs.html) and really like them for the street and they are a good match for the Tokico struts. They are 200 in. lbs. rear and 180 in. lbs. for the fronts, so they are stiffer than the euro springs but not too stiff for the street (IMO). They will lower the car about 1" though.
Eibach progressive rate springs are nice I hear. They have a soft ride at normal driving, and get stiffer the more you push it. They are expensive though. I have Suspension Tech springs on mine. They are stiffer than the originals, and lower my car aout an inch. That is LOW for a 240. I have already pulled one exhaust sytem off on a manhole cover. I think I may get the eibach springs for next summer though. I don't think they lower the 240's any. Also the Arizona Z car springs don't lower the 240's, but will lower the 280's.
  • 3 weeks later...
The tire size i'm running is 215 60 14 with the Euro springs. I understand the Euro springs are no longer made, so I'm considering a new spring, but I don't want it slammed to ground for a rough ride. Any suggestions?
Hi Gang:
Thanks to Bryan's tireless efforts, we had the US Spec. Stock Springs reproduced in limited quantity. If you call David House at Courtesy, tell him you are a member of either the Internet Z Car Club (IZCC) or the Classic Z Car Club - you will get the special pricing we worked out for our members.
Retail on the Internet will be $259.95 for a complete set of four springs (very very reasonable by todays standards), and the club price will be $229.95 plus shipping (a bargain!). This is actually just a "service" done as a favor for us by Courtesy Parts... and another reason we should perfer to give them all our business.
If you think you want a new set of Stock Springs - I would suggest that you buy them now. As I said, the quantity we had produced is limited. (only 20 sets available.. and most likely less than that now). Grab them and stick them on the shelf for later if your not ready to swap out your tired old springs yet.
We are working on having the Euro Spec. Stage I Springs reproduced next - hope to have them available in limited quantity just after the first of the year.
These springs are produced my a major OEM to the US car manufacturers, right here in the USA. They are shot peened for stress relief, sprayed with the semigloss black and dabbed with the correct color paint dabs.. Each Set consists of One Right Front, One Left Front and Two Rears - sorry but sold only as complete sets.
When you call Courtesy - ask to speak to David House as he is aware of the special club pricing... tell'em Carl told you to call.
FWIW,
Carl
Carl Beck
Clearwater,FL USA
http://ZHome.com
Do the Tokico springs lower the 240Z? I'm thinking of getting a kit that includes the Tokico HPs and springs for $349.
I have the Tokico Illuminas and springs - lowers the car about the same as the ST springs I replaced. The ride is very tolerable on settings 1 or 2 for street driving (our roads are not the best here!) and the higher settings on the Illuminas is great for performance handling.
  • 3 weeks later...
Hi Gang:
I now have a set of NOS Nissan Euro Spec. Stage I Springs, as listed in
the older Datsun/Nissan Competition Parts Catalogs. These were just
slightly stiffer than the US Spec. OEM springs and were a very
popular upgrade to the 240-Z's suspension, without resulting in a
significantly lowered car and a harsh ride.
I am putting together a group purchase in order to get this NOS set
Reproduced, as they have been NLA from Nissan for several years now.
This will be a very limited production quantity, they will be
manufactured by a US manufacturer, shoot peened for stress relief,
painted black and marked with the correct color paint dabs (just as
the originals were). All spec.'s will be the same as the originals..
free length, installed height, and spring rates etc.
Pricing will be very reasonable for the Group Purchase, so if you are
interested in ordering set let me know now, and I'll add your name to
the Group along with the quantity of sets you wish to pre-order.
You will pay for them, only after they are manufactured and ready to
ship... and you will know ahead of time what the final pricing will
be. (final pricing will be somewhat dependant upon the total number
of sets we have manufactured - but are expected to be well below
Nissan's last list price from years ago).
They should be shipping at the end of the year or just after the first.
If you would like to order a set, or have questions - e-mail me at:
beck@becksystems.com
regards,
Carl
Carl Beck
Clearwater, FL
http://ZHome.com
  • 7 years later...
Hi Dave:
I do not know of a retail source for either of the spring sets. You might find a set on E-Bay, or buy them from someone like me - that has a few sets.
We have learned a lot since 2005.
First - the Euro Spec Springs combined with modern Gas Pressure Shocks - will not lower your 240Z - the combination will RAISE the ride height of the car - in some cases by as much as 1 1/2 to 2+ inches! To get the rid height back close to original - most guys had to cut 2 to 2 1/2 coils off the springs.
The same is true for the Stock Springs combined with modern gas pressure shocks. Although fewer coils had to be removed. These newer gas pressure shocks have significantly more gas pressure than they did 20 years ago. So with the upward force they have - they unload some of the normal pre-load exerted by the corner weight of the 240Z's {around 650 lbs}.
That Said:
I still have the NOS Euro Spec. Stage I springs that we used for the model from which to reproduce them. I'd sell them for $400.00 plus $50.00 for packing and shipping anywhere in the US.
I also still have a couple of sets of the "Stock" Reproduction Springs. I'd sell them for $279.00 plus $40.00 shipping and handling anywhere in the US.
US Postal Money Order or PayPal.. Drop me an E-Mail or PM if you can't find anything for less. I'm in no hurry to sell them..
FWIW,
Carl
