Site Updates this Weekend ×
I just want to ask a silly question .. but I would like to be sure about this .. Are the doors of a 71 240 the same as doors from a 77 280 ? Can I swap them ? I have a parts car (71 240) and am using some of its parts from my 77 280 . If i can I may restore the doors from my 240 and then swap them onto my 280 without being without doors for a lenght of time. The 280 is my driver.
Thanks ..B
https://www.classiczcars.com/topic/17468-doors/
Mid year on the 74 260z.
Okay, you made me research it. According to this post: http://www.zcar.com/forums/read.php?f=1&i=587619&t=587615, it was in 76. (Edit: Just to clarify, the post I linked specifically talks about windows interchanging, but I believe the author implied that the latching hardware changed at the same time.)
So, who is going to the next big meet to research and document the answer? :)
https://www.classiczcars.com/topic/17468-doors/#findComment-140257
IIRC, the doors are basiclly the same 1971-1976. Some changes to the interior door panel, changing the armrest, opening mech. attachment and different intrusion protection inside the door. The 77 & 78 doors had the door lock pull moved about 3" forward and the latch mech was changed. The 77 & 78 will not work on an earlier Z without much time and expense.
https://www.classiczcars.com/topic/17468-doors/#findComment-140281
Good to know. So to summarize, if I need to replace the doors on my early '71 (and I may need to), I can use later doors (with minor mods) as long as they have the same type door striker. Probably up through '76, subject to verification. Sound right?
https://www.classiczcars.com/topic/17468-doors/#findComment-140282
There is one big caveat. The donor car CANNOT be a 2+2.
Oh, and I think you have to go to the pick and pull on an odd Tuesday with a full moon to ensure full compatibility.
https://www.classiczcars.com/topic/17468-doors/#findComment-140286
