mars23z Posted October 3, 2005 Share #1 Posted October 3, 2005 Is the clutch slave adjustable on a 1974 260z? If so how do you adjust it?Thanks Chris Link to comment https://www.classiczcars.com/topic/17477-clutch-slave/ Share on other sites More sharing options...
loy Posted October 3, 2005 Share #2 Posted October 3, 2005 no not adjustable. Is it not coming out far enough. Maybe you need to bleed it. Or u coudl try adjsuting the pedal Link to comment https://www.classiczcars.com/topic/17477-clutch-slave/#findComment-140317 Share on other sites More sharing options...
cremmenga Posted October 4, 2005 Share #3 Posted October 4, 2005 My parts car is a 72 and i had the same problem. I could adjust the slave a little tiny bit by unscrewing the rounded nut where it bolts in to the clutch/tranny underneath. It did help. Link to comment https://www.classiczcars.com/topic/17477-clutch-slave/#findComment-140354 Share on other sites More sharing options...
montoya_fan01 Posted October 4, 2005 Share #4 Posted October 4, 2005 My parts car is a 72 and i had the same problem. I could adjust the slave a little tiny bit by unscrewing the rounded nut where it bolts in to the clutch/tranny underneath. It did help.The clutch slave cylinder on a 72 IS adjust able BUT, it is NOT the same as the one on a 74.As loy stated, the clutch slave cylinder on a 74 IS NOT adjustable. Link to comment https://www.classiczcars.com/topic/17477-clutch-slave/#findComment-140362 Share on other sites More sharing options...
cremmenga Posted October 4, 2005 Share #5 Posted October 4, 2005 The clutch slave cylinder on a 72 IS adjust able BUT, it is NOT the same as the one on a 74.As loy stated, the clutch slave cylinder on a 74 IS NOT adjustable.sorry thought they were the same Link to comment https://www.classiczcars.com/topic/17477-clutch-slave/#findComment-140368 Share on other sites More sharing options...
loy Posted October 4, 2005 Share #6 Posted October 4, 2005 u could try to mount the slave cylinder closer to the withdrawl lever. I myself is having a clutch problem but it's due to letting my z sit for to long and teh damn flywheel rusted Link to comment https://www.classiczcars.com/topic/17477-clutch-slave/#findComment-140391 Share on other sites More sharing options...
cremmenga Posted October 4, 2005 Share #7 Posted October 4, 2005 I have a new master and slave cylinder off of my '72 that i just bought a few months ago, I ended up buying another car and now I don't need that one so if anyone needs them it theirs also! Link to comment https://www.classiczcars.com/topic/17477-clutch-slave/#findComment-140437 Share on other sites More sharing options...
