My parts car is a 72 and i had the same problem. I could adjust the slave a little tiny bit by unscrewing the rounded nut where it bolts in to the clutch/tranny underneath. It did help.
The clutch slave cylinder on a 72 IS adjust able BUT, it is NOT the same as the one on a 74.
As loy stated, the clutch slave cylinder on a 74 IS NOT adjustable.
https://www.classiczcars.com/topic/17477-clutch-slave/#findComment-140362
  • Who's Online   1 Member, 0 Anonymous, 561 Guests (See full list)
