I know how anal these cars are about air leaks and such, I was just wondering if I put a breather filter on the valve cover outlet would it make the car run bad or will the idle stay the same. I was thinking it would be like taking off the oil cap while the car is running. Thanks
https://www.classiczcars.com/topic/17481-breather-filter-on-valve-cover/
No it wont have and effect on the idle on a 240 or 260 but on the 280s it will . The side effect of a little filter on the valve cover is you will have fumes in the cabin . If this on a carbed Z with the stock air cleaner there is no advantage in not connecting the hose to the the air filter like was done originonally . GAry
  • Who's Online   1 Member, 0 Anonymous, 573 Guests (See full list)
