Actually, you've got a couple of ways you can do it...
DIY....POR15 after having tank hot-tanked for several days. Multi step process (Fairly cheap)
Have someone else do it...(Slightly more money)
Send it off to somewhere like "Tank-Renu" (Price will vary depending on condition of tank. Could be anywhere in the price range of $300-$400+ or higher) Do a search on "Tank-Renu" and you should come up with several url's for websites.
webdawg1
actually, wait a couple of days, and you can see my completed tech article on POR15ing the gas tank inside and outside....I'm about half way done with it. Check it out here:
http://www.classiczcars.com/forums/showthread.php?t=19034
The #1 thing, is get the tank boiled at a radiator shop...the tank kit from POR15 for just the sealing is like $50 and is real easy to do. I couldn't believe how easy it was, and it is permanent--you'll never have to worry about the inside of your tank again...
  • Who's Online   0 Members, 0 Anonymous, 1,292 Guests (See full list)
