fisherman338 Posted October 15, 2005 Share #1 Posted October 15, 2005 I picked up an '83 280ZX non turbo for my nephew. Is the injector wiring color code the same as on an '82? Also, are the turbo injectors the ones with the little nipple on the end of the injector? I'm trying to find out if these injectors are from a turbo or non turbo. Thanks for any info you can give me... Link to comment https://www.classiczcars.com/topic/17624-83-280-zx-non-turbo-injector-wire-color-code/ Share on other sites More sharing options...
fisherman338 Posted October 16, 2005 Author Share #2 Posted October 16, 2005 This just a bump to 'refresh' the thread. Please, someone help me out on this. It seems a pretty simple question to me. I got a service manual but the wiring schematic only goes to 1982, even though it's supposed to be through 1983. That's why the question... Link to comment https://www.classiczcars.com/topic/17624-83-280-zx-non-turbo-injector-wire-color-code/#findComment-142002 Share on other sites More sharing options...
hls30.com Posted October 17, 2005 Share #3 Posted October 17, 2005 I am not sure why you need the color code for injectors, they are non polarized(they will fir even with reversed polarity) As to finding out what the enjectors were made for, the numbers on them are the best way to find out-check google for the flow rates on the injector numbers you have-that will enable you to find out where they belong.Will Link to comment https://www.classiczcars.com/topic/17624-83-280-zx-non-turbo-injector-wire-color-code/#findComment-142052 Share on other sites More sharing options...
fisherman338 Posted October 17, 2005 Author Share #4 Posted October 17, 2005 This is a non running car. The injector rail was not installed. I need to know the color code so I can wire up the injectors. You know, pulse wire set #1 to injector #1, etc, etc. Thanks for the response. Link to comment https://www.classiczcars.com/topic/17624-83-280-zx-non-turbo-injector-wire-color-code/#findComment-142059 Share on other sites More sharing options...
fisherman338 Posted October 18, 2005 Author Share #5 Posted October 18, 2005 I found another post talking about testing resistance in injectors & ICM. Found out which wires in connector to ICM for which injectors & was able to figure out color code... Link to comment https://www.classiczcars.com/topic/17624-83-280-zx-non-turbo-injector-wire-color-code/#findComment-142255 Share on other sites More sharing options...
