Glad you got it running good, but this is the first time I've heard of having to set it 1 tooth off in that direction.
However, it does prove the point that the illustrations in the manuals can't always be taken as being 100% correct in every situatuion. Hard to figure out why this happens, but to my way of thinking, the only variable is the adjustment bolt between the distributor and the distributor base. Timing chain doesn't come into play in this situation, the oil pump & distributor d/s is gear driven so there shouldn't be anything to cause variance there.
Yeah it runs like a bat outa hell. But now I ran into a problem with the shifter not fitting into the console. I used the original that I got with the 5 speed from pick and pull but for some reason it doesnt want to go into 1st gear because it hits the middle console. I got the 5 speed from a 1979 280zx, I dont know if there is any difference in the shifters, could someone let me know if I have the wrong shifter? Thanks
