On 8/13/2011 at 7:09 PM, 240260280z said:
Just to update this thread (6 years later on):
It is interesting that prices have not changed much! :)
I just picked up two SU kits from Black Dragon (Victoria British) and the quality was poor thus the spur to revise this post.
Black Dragon
Manufacturer: Wells
Part Number: CK749
It only includes:
- Fuel bowl needle valve assembly and gasket (much shorter assembly than the two I have in the carbs and not easy to disassemble like the originals).
- Fuel bowl top gasket (very thin paper material)
- Carb to manifold gasket (very thin paper material)
- Rubber gasket for plunger (very thin rubber)
- Clear plastic spacer for spring base (very thin clear plastic)
- Fuel bowl drain gasket
- 2 paper washers different colours and materials (for fuel banjo I assume?) I was hoping they would be aluminum like the existing ones.
- 3 mystery paper washers (not sure where they go? ID of hole is 10mm and OD of washer is 14mm) Any ideas? Cooling passages?
- fuel hose (best part of kit)
The gasket paper changed between the two kits I received.
The documentation was generic and did not show where gaskets go however it was informative:
Page1:
Page2:
This is my 2nd kit. At least the gasket material is the same in this one.
Comments:
This kit needs front gasket for carb and metal banjo gaskets then it would not be so bad. A fuel filter sock, taller needle valves, and better quality paper would also be improvements.
Z Therapy
ZT150 $180.00
Complete Tune Up Kit for 2 carbs
(Needle & seats, SM, N27, N54, or N58 needles, ZT Nozzles, float gaskets, gas lines, banjo seals,4 insulator gaskets, JustSU's DVD) This cost includes a $50
CORE CHARGE
on your old nozzles. Send back your old nozzles for $50 refund.
Comments:
The ZT kit is more of a serious overhaul kit than a refresh kit. It has too much core stuff that I do not need to change (DVD, Nozzles, Needles) . As well the core hassle for nozzle exchange is not my cup of tea. I think ZT would benefit from adding a basic refresh kit to their product line. (quality gaskets & hose & needle valves)
Motorsport Auto
I looked at the MSA kit and it looks a lot like the kit I received from BD only it is ~ 50% more expensive. Even the way the wire holds the needle assembly is the same.
Ebay
This all Nissan kit from Japan is good value for $30. Does two carbs.
Best Value seems to be this 72 240z Keyster Kit for $30. It does two carbs and has needles too!
Needle valves look aftermarket.
Bought the keyster kit and the needles dont seem to fit? They have hwj 4 on them? Redt of the kit looks good
3 minutes ago, Mark Maras said:
 Are the needles to small, as in .090" instead of .100"? I don't recall any hwj 4 needles conversations in the past.
Ive done my fair share of needle research and they are too large. I have 3 screw carbs. They dont fit into the piston. Maybe my pistons arent .100?
