Here's another spreadsheet I currently have done that can be posted for general use by all concerned....Remember to make any changes to the spreadsheet(s) based on your model year (I.E. - 240, 260, 280) as there will be "some" differences between model years...but for the most part should be pretty accurate...It also helps if you have the Z Microfiche CD-Rom so you'll know what to change in the various spreadsheets for your model year...
webdawg1
Fiche 65-1 Side Marker Lamp.xls
webdawg1
Fiche 103-1 Steering Wheel (From Aug '73).xls
webdawg1
Fiche 97-1 (Brake & Clutch Pedal).xls
webdawg1
Fiche 139-1 Tail Gate Window (From Aug '73).xls
  • 3 weeks later...
webdawg1
Fiche 37-1 Air Cleaner L28E (From Dec 74').xls
  • 3 weeks later...
Here's some more spreadsheets I currently have done that can be posted for general use by all concerned....Remember to make any changes to the spreadsheet(s) based on your model year (I.E. - 240, 260, 280) as there will be "some" differences between model years...but for the most part should be pretty accurate...It also helps if you have the Z Microfiche CD-Rom so you'll know what to change in the various spreadsheets for your model year...
webdawg1
Fiche 42-1 Water Pump & Fan Belt L28E (From Dec '74).xls
Fiche 71-1 Clutch Disc, Clutch Cover & Drawal Lever.xls
  • 2 months later...
Have not posted anything for a while....working on the house quite a bit lately...(Long story) thought I would throw out just a simple little spreadsheet to help track the progress with part ordering and that sort of stuff. Change the headings to what ever you would like to put in there to suit your own needs. Kind of helps when you have all your part numbers, and other miscellaneous data all in one place when you go by the dealership to order parts...etc...etc.
webdawg1
Parts Needed (Blank).xls
  • 8 months later...
webdawg1
Fiche 170A-1 (Emblems From Dec '74).xls
  • 4 months later...
Have not posted anything for a while....Here's another spreadsheet I currently have done that can be posted for general use by all concerned....Remember to make any changes to the spreadsheet(s) based on your model year (I.E. - 240, 260, 280) as there will be "some" differences between model years...but for the most part should be pretty accurate...It also helps if you have the Z Microfiche CD-Rom so you'll know what to change in the various spreadsheets for your model year...
webdawg1
Fiche 140-1 Door Panel, Glass & Hinge (From Aug 73 two Seater).xls
  • 2 years later...
Have you seen the "240Z Restoration checklist"? It has the entire car catalogued with instructions on what to do with each part, and could be used a a model for your spreadsheets. http://www.jasonjarvis.com/main.html
BTW... Today is Mr. Blakes birthday, among others. Check the homepage for all of today's birthdays.
Edited by TomoHawk
  • Who's Online   3 Members, 0 Anonymous, 1,444 Guests (See full list)
