The Jatco trans was used in a number of cars and small trucks, so that might give you an idea of how it holds up.
The Jatco trans had a couple four speeds- one with a hydraulic lockup converter, and one with electric. Will is working on how to hook one up to the L28 engine in the S30 car. Mostly you need a modified trans mount and custom drive shaft.
https://www.classiczcars.com/topic/17703-automatic/#findComment-142774
Well a Maxima over here is ... a Maxima !
Back to the post, who have a perfo/auto in the club?
Could it run in the low 8' for the 0-60 Miles whithout trashing the box?
The handling of the Z is so Kart like that a perfo auto/Z would be fun (if not the fastest) around a track, no?
https://www.classiczcars.com/topic/17703-automatic/#findComment-142820
I am exploring the 4 different varieties of Jatco 4NB to find which one is the strongest-probably for the same reasons you are asking these questions.
The swap from the Maxima OD has been done, and is outilnes in a tech article on one of the other Z sites. I had no involvement in that, buit it looks fairly easy to do. The reccomended autood tranny for a high output engine is the Jatco out of a Turbo Mitsubishi starion, add to that some 300Z pieces, and you have the group the author of the article reccommends.
I went looking for the article on both HyridZ and Zcar.com, but did not find it.
I did copy the article, and will see if I can I can find it.
Will
https://www.classiczcars.com/topic/17703-automatic/#findComment-142834
My first Z was an auto and did 0-60 in about 8.5. Trans held up fine for several years. I used to manually shift it a lot on windy roads, never had any trouble with the transmission at all. I had planned to swap in a 5 speed but got rear ended and the car was totalled.
https://www.classiczcars.com/topic/17703-automatic/#findComment-142836
I did the 4n71B swap in my 78. You need to remove the trans mount ears from the floor pan. Have a driveshaft made and add a radiator with a fluid cooler.I fabricated a trans rear mount and wired the inhibitor switch. The rest is pretty much a bolt on. For hi performance use there is a company in AUS that makes HI PERF parts. I found their web site by searching "4n71B transmissions". I did the conversion to make my car a better road car. RPM's dropped to 1200 at 60 MPH.
https://www.classiczcars.com/topic/17703-automatic/#findComment-142837
