texasz Posted October 31, 2005 Share #1 Posted October 31, 2005 Here's the Mikuni PHH Manual for anyone who needs it.Mikuni PHH Manual.pdf 1 Link to comment https://www.classiczcars.com/topic/17817-mikuni-phh-manual/ Share on other sites More sharing options...
EricB Posted October 31, 2005 Share #2 Posted October 31, 2005 Awesome - thanks so much!-e Link to comment https://www.classiczcars.com/topic/17817-mikuni-phh-manual/#findComment-143874 Share on other sites More sharing options...
terceldude Posted October 19, 2007 Share #3 Posted October 19, 2007 texasz, Hello, I am a new member to this site and forums. I joined only because of the Mikuni carb, Weber, and Solex carb info. Do you think you can e-mail me the Mikuni PHH Manual ASAP as an attachment to coolkevin366@yahoo.com, just in case it doesn't work? Also, I own a Toyota Tercel 4WD Wagon from 1987, but was thinking of modifying it to these carbs. Could you help in any way? Thanks, Kevin. Link to comment https://www.classiczcars.com/topic/17817-mikuni-phh-manual/#findComment-225402 Share on other sites More sharing options...
terceldude Posted October 19, 2007 Share #4 Posted October 19, 2007 I would want the Weber DCOE, DCO, Dellorto DHLA, Solex ADDHE, Hitachi and Mikuni-Solex ones as well, if possible. Thank you. Link to comment https://www.classiczcars.com/topic/17817-mikuni-phh-manual/#findComment-225403 Share on other sites More sharing options...
Zs-ondabrain Posted October 19, 2007 Share #5 Posted October 19, 2007 does ANY ONE have the manual for the 40 DCOE 151 Webers with the "air bleed screw" (white caps) They seem to be next to impossible to find.I would REALLY appreciate it.Dave. Link to comment https://www.classiczcars.com/topic/17817-mikuni-phh-manual/#findComment-225405 Share on other sites More sharing options...
Glenn Brenan Posted January 30, 2008 Share #6 Posted January 30, 2008 Hi there, thank you for the access to your Mikuni manual. I have triple 44mm units on my 72 240. The engine is fresh and I can't get the damn thing running. The car sat for 18 yrs ... I thiought all was cleaned up and ready to however it is not to be, so this info will help ... Cheers ..GB Link to comment https://www.classiczcars.com/topic/17817-mikuni-phh-manual/#findComment-235789 Share on other sites More sharing options...
ExtremZlucky Posted February 22, 2009 Share #7 Posted February 22, 2009 I was unable to download it. It says the document is damaged? Link to comment https://www.classiczcars.com/topic/17817-mikuni-phh-manual/#findComment-275063 Share on other sites More sharing options...
blue 72 Posted February 22, 2009 Share #8 Posted February 22, 2009 I just tried and it worked fine for me. Did you right click on the file and select "save file as" or "save link as"? Link to comment https://www.classiczcars.com/topic/17817-mikuni-phh-manual/#findComment-275079 Share on other sites More sharing options...
ExtremZlucky Posted February 23, 2009 Share #9 Posted February 23, 2009 Hmph.. thats odd. Yesterday It did not work hitting Save as.. Nevermind!Thanks a million! This is EXACTLY what I've been looking for! Link to comment https://www.classiczcars.com/topic/17817-mikuni-phh-manual/#findComment-275144 Share on other sites More sharing options...
