I agree Arne. Pir0San remember that the float in the bowl will determine the level of the fuel at the opening of the nozzel. You are almost there with the proper fuel bowl level/ float level adjustment. The float level is a rough adjustment, then you fine tune this fuel level with the adjusting nut on the nozzle. The nut will raise or lower the nozzle for the fine tuning. Only make 1/4 turn adjustments at a time. Give the throttle a couple of good raps, let it the rpms settle before pressing the lifting pins for the dampner test. You only want to lift the test pins about a 1/16th of an inch, not much. Listen to the rpm changes and make another adjusting nut change according.
Adjusting nuts maybe alittle different from each other depending on the float level in each and the carb condition itself.
Make small adjustments and be sure the car in warmed up. The oil in the dampner will not effect idle or mixture.
Thanks for all of the help guys, I'm trying to trace this problem down.
You are totally right, the oil in the dampner will not affect mixture or idle speed at idle, but will affect mixture when accelerating, but I'm sure you knew that :laugh: , I was just thinking that the velocity of the air pulling on the dashpot might have to correlate with the dampner oil.
I think you can try again at raising the fuel level in the bowl by bending the float tab so the float is closer to the lid. This will give the bowl a high fuel level and in turn it will also raise the fuel level closer to the top of the nozzle in the bottom of the carb. Then again start the adjusting nuts at 2 1/2 turns open and start the car. Hopefully with the choke off, or closed.
When you pull the choke, the cable will pull the nozzle jets down and this raises the fuel level at the tip of the nozzle allowing for alittle more fuel on cold starts in the morning, gives little more fuel to get the cold blooded animal going, until it warms. This is what Arne is saying about proves the theory of float level still off, too low.
yeah, mine are the stock 3 screw carbs from my 240Z. Why do the drain plugs make a difference, out of curiousity?
Just to make sure I read what he said right, put the clear line on the bottom of the float bowl, turn the motor over until the fuel inside of the plastic line stabilizes (air is bled out), and the put the line up to the mark I made on the float bowl, and adjust the float setting until the fuel in the plastic line is at the same height as the fuel in the float bowl?
Oops! I didn't see that part. I was assuming he was having you connect to the float drains like the ZTherapy kit. If you are connecting to the bottom by disconnecting the hose to the nozzles it shouldn't matter which style float bowl you have.
And no, you want to adjust the float level until it matches the line you marked at 23 mm from the top. The level in the clear hose will always match the level inside the bowl.
quick question, when setting the float adjustment, and the float bowl top is upside down so that the adjustment can be made, is the float supposed to sit at 9/16 under it's own weight, or am I supposed to hold the float until it just touches the needle, and go from there?
If you have the standard needle and seat setup with the internal spring, turning the lid over will give a setting where the float will be way too low. You need to hang the float vertically while blowing gently into the fuel inlet tube. Move the float toward the lid and you'll feel when the shut off happens. Not allowing for that internal spring will screw things up to the point you will be found whimpering in the corner.......
Question: How does the car run with the carb nozzles set at 2 1/2 turns from the full up position? I don't think you were that far off from the start, that you could not have adjusted your way out of it by adjusting the metering nozzles. What needles are you running? Where ever you end up with the nozzle you're going to want the fuel level in the nozzle (float bowl) 1/16" or so below the top of the nozzle.
That would explain a whole lot. Thanks for the insight, Bruce!
I was off by something, because when I went to set my adjustment, nothing happened. I was running extremely lean, causing a lean backfire out of the carburetors, and the car would only run right when the choke was all of the way out.
That's why when you pull the choke on to get it to run it's like screwing the nozzle down at least a couple of turns. Get those nozzles cranked down a couple of turns and see what happens. We send everything out of here set at 2 1/2 turns down and I'd be interested in knowing how many cars are out there never haveing been moved from there. Just a good square one position for most applications. A tweak up or down is about all that is needed in most cases. Any major tweaking is often an indication of something else amiss......
When using the 23mm mark as suggested, where is this measured from? The top of the float bowl, as in the line between the float bowl cover and the bowl itself, or the top of the cover?
I just ordered one of Bruces's rebuild kits so I'm going to be doing this myself in a week or so.
  • Who's Online   0 Members, 0 Anonymous, 1,210 Guests (See full list)
