If that's the 1/4" fuel/vapor line coming from the vapor tank in the back right hand side, (Passenger side) which passes thru the rear right side frame member....Then that should be a one way "check valve"...If you trace it all the way to the engine compartment then it (The line) should end connecting to the vapor cannister.
webdawg1
https://www.classiczcars.com/topic/17889-what-is-this/#findComment-144668
  • Who's Online   1 Member, 0 Anonymous, 793 Guests (See full list)
