I've got the vise grips on the line and will pull the top off the pump tonight but is there anything inside the pump to be concerned about(parts falling out) . P.S read all your other F.I. posts and will go after air regulator, bccd and altitude switch next (high idle) just figured on doing strainer while suspension is out.
https://www.classiczcars.com/topic/18020-fuel-strainer/#findComment-146040
  • 3 months later...
