I have a small problem with my left turn signal I can not seem to run down. The signal has stopped working when I activate the turn signal lever on the steering column.
The hazard switch activates the signal and the parking/running lights work.
This leads me to believe it is the steering column switch that is malfunctioning.
Any opinions???
Keith:tapemouth
https://www.classiczcars.com/topic/1815-turn-signal-malfunction/
Well, if the right ones flashes OK then it probably is in the switch. Before you start tearing it apart check one thing first, check to see if your steering column cover panels have moved and are not allowing the stalk to completely activate the switch. It's happened to me before, so try it and see what happens.
Try some spray contact cleaner into the switch before you start looking for another switch. They aren't cheap, unless you get lucky enough to find one used from the same year car. They have different plugs that connect to the wiring harness, so you will need to find one with the correct plugs. I know that there is a difference between 72 and 74, not sure how many are interchangeable.
It is always good to hear some support.
Actually, the cover panels are off as I have had to replace the light stalk on the column and have had to dismantle the ignition switch to remove the door key several times due to worn tumblers and worn levels of attention when inserting the correct key.
I am of the understanding from more knowledgable Z parts guru's that even different '73 versions have different switch harness connectors. I was able to go through a bucket of light stalks in Denver at Fortunz of Wheels to find one that worked on my '73.
I need to do some rewiring of harness conncetors because of "meltdown" that has occured in them over the years causing me to have to cut and splice individual wires that have been burned through in the old connectors, so, I think I will remove and disassemble the turn signal switch to see if I can rebuild the worn assembly. I was successful doing this with the original fan switch for the heater/AC.
Will update...
Keith
OK, so much for my silly idea. Now for another one. Have you looked at the taillight bulbs? I have seen taillight bulbs blow a filament, and the filament breaks and crosses over to the other filament and causes all sorts of weird things to happen. I've seen a taillight short out all the lights on a trailer when I worked in a truck shop many years ago. Never hurts to look right?
Only other thing I can think of is to check the ground wire that connects the headlight and turn signal switch and the ground wires on the wiring harness in the engine compartment.
If it's not there then it probably will require some work and/or replacement of the switch at the stalk.
It could possibly be just the globe socket. Due to just deteriation over time via water and dirt the globe terminals won't connect properly. I have also had to change the socket wiring because it had gone hard and brittle and the current just wasn't getting through anymore. However this would some times be evident by a faster flashing signal on the other side of the vehicle.
Hope this helps..........;)
Gentlemen,
All of your suggestions of possible cause are viable, I think I will get out the volt meter and explore these potential causes prior to removing the signal stalk.
I had never heard of the filiment short before. The rear signal does function which is one of the baffling things about this...
thanks
keith
Ok, from the last post what I surmise is that it is only the FRONT signal that is not working. The rear component of the turn signal (left) IS working.
Therefore to summarize:
Both RIGHT hand lights work as they should, including the indicator in the Tach.
LEFT: only the indicator in Tach and the REAR light. The FRONT LEFT indicator is the only thing NOT working.
Conclusion: Turn Signal Flasher is operative, wiring through combination switch is ok for the rear, check wiring for left front, bulb check required left front, ground check required left front.
If this is correct, then there is only a couple items to check.
We need to do THESE simple checks FIRST, before we address the more complex issues suggested. This is Occam's Razor.
At the combination switch, look for a Green wire with a RED stripe (shorthand for this is Green/Red wire) Check continuity on that wire from the combo switch all the way to the light socket at the front of the car. If no problems, (also check for short to ground), then check to make sure the light socket has good contact to ground. That's the black wire at the socket, run continuity through it to ground. Lastly, check continuity on the bulb.
If ALL those check ok, then we can start looking at the other possibbilities, such as short to the parking light circuit. But I'll bet that this solves it.
This is the response I have been looking for. I have serveral wiring diagrams for my model and year configuration, however, what I have found to be true is that different systems are wired uniquely.
In other words, the A/C wiring matches the diagram out of the Haynes early model S30 diagram whereas the AT matches the late model diagram from Clymer manual.
My '73 was manufactured in 11/72 and seems to have different production components mixed throughout the systems.
I will pull my meter and long leads with aligator clips out tommorrow evening and pass the data back though this thread
A million thanks for the wiring codec.
Keith
i had the same prob w/my z. what i did: checked all bulbs to insure correct bulbs in place, removed/lubricated and reinstalled signal actuator on column, finally-bought a new flasher unit. problem solved and signals work great.
hope this helps...
  • 6 months later...
Over the past few months the indicators (turning lights) on my 240 have gradually ceased to function. Having read other posts, I decided to pull apart the indicator stalk assembly and clean the switches up a little - low and behold the indicators have started to work again albeit somewhat randomly. The only thing I didn't do was take apart the little contact assembly which clearly is the bit that needs a good cleaning. Because this small assembly is held together with a couple of tabs I didn't want to go pulling it apart and find that I couldn't reassemble the damn thing.
Can anyone tell me what is inside there? Is it straight forward to take apart and re-assemble or am I going to be confronted with fiddly little parts that I can't put back together or worse still - lose.
There must be a reason that the switch mechanism was assembled this way. I'm just wondering if it was to keep enthusiastic amateurs like me well away from it!
Thanks in advance!
On my car, all I had to do to fix this problem was to remove the plastic "surround" clamshell and spray Electrical contact cleaner all around and through the mechanical parts of the turn signal assembly to remove all the "FUZZ and crap that has collected in there. I then LIGHTLY re-lubricated places where moving metal parts contacted each other. I also sprayed the contact cleaner inside the switch that you mentioned.
That solved all of my problems, and they have not recurred for 3 years. It's cheap and easy! Give it a try.:D
  • 1 month later...
Sorry about the delay on responses. Have been busy with much ado about nothing.
I was using the doctine of double effect otherwise known as the lesser of two evils in my troubleshooting of this problem.
However, the principle of Occam's Razor, "pluralitas non est penenda sine necessitate" or dont't create unnecessary entities, was in fact the correct application.
Thank you you saved me many troublesome hours of diagnostic torture.
Keith:stupid:
  • Who's Online   3 Members, 0 Anonymous, 1,390 Guests (See full list)
