it is a copy, I have one of the originals, and one bought from Showcar parts-it is a good quality piece, and only slightly different from the original-I will see about putting them together in the same place, and posting a picture(neither is mounted-though the BRE has been)
https://www.classiczcars.com/topic/18185-spook/#findComment-147668
did either one come with a template, bolts and washers? i would think the ebay one u only get what u see.
https://www.classiczcars.com/topic/18185-spook/#findComment-147673
The one from showcarparts came in a box with packing-no hardware, but the mounting locations are molded in-though not drilled, the picture is below, the one with the sticker and black on the back is the showcar parts one-it is also noticeable heavier than the BRE, but not by a bunch.
The picture didn't take, I'll try again below(in another post).
https://www.classiczcars.com/topic/18185-spook/#findComment-147674
Arne thanks for supporting Les because I agree, we need to support vendors that specialize in manufactured parts for our cars.
Les's part has marks in the fiberglass for the mounting points (most knock offs do not). I don't believe that they include hardware, but you can call Les regarding the specifics.
https://www.classiczcars.com/topic/18185-spook/#findComment-147676
  • Who's Online   1 Member, 0 Anonymous, 1,534 Guests (See full list)
