What all does the cartridge include and where do I get one. I called a turbo shop here in Oklahoma and he looked it up and told me if the shaft was broken I would need a new "center piece" and said it would be $600.00.
Well someone is ripping you off if the are charging you 600 dollars for a new ?center section" Cartridge as hls30 has properly called it.
My new Garret T3/T4 cost just over 600, so if that tells you anything then you might want to reconcider.
Go to www.speedshopthagard.com he is a reputable seller and aslo a Zcar owner. You can go wrong with James Thagard, he knows his business and what hes talking about.
Good luck
  • Who's Online   0 Members, 0 Anonymous, 1,307 Guests (See full list)
