is it posible to bring the distributor drive spindle out and in the rigth drriction without to removed the oil pump ???? or can i only do this from the oil pump side ?? is it correctly if the crankshaft is at the upper dead center the distributor drive spindle must stand on 11 clock ??
apology for this stupid ask however I makes that for the first time
THANKS
https://www.classiczcars.com/topic/18496-distributor-problem/
