Best Place to Acquire New Chrome Window Trim?
If you're talking about the trim that holds the black window squeegee I found that aftermarket version (I can't remember if I got it from MSA or VB) is much thinner and cheaper than the original and doesn't go on very well. It tends to get wavy when it's installed. I mainly needed new pieces because the rubber was dry and cracking. I ended up removing the rubber from the new units and installing it back on the original trim piece. It would be much better to find OEM replacements in my opinion.
  • Who's Online   1 Member, 0 Anonymous, 1,431 Guests (See full list)
