I need help in reference to the tail light gaskets. I just received them and both are the same. Both have a recessed area for the bolt/nut to go through. Would it make a difference if one of the gaskets (right side OK) left side is reversed, all holes match up and appear to be OK on the left side. Should I use contact spray to hold in place while installing them? Any help will be appreciated!!!
Randy
rbm260z
https://www.classiczcars.com/topic/18631-help-tail-light-gasket/
I have a 240 so I don't know about the 260 weather or not that they are sided or not. However dont use spray adheasive use a THIN coating of silicone sealer. This way it will seal real well and if you need to remove it some day it shouldnt tear .
  • Who's Online   0 Members, 0 Anonymous, 951 Guests (See full list)
