Runs rich after 10 minutes of running
Clean the wire connections to the Thermotime Switch. Located on the thermostat housing. The wire connections are a slip fit on the manifold and sometimes corrode leaving a bad connection or the swtich may be defective. This switch tells the computer that the engine has warmed up and it can cut back the fuel enrichment after start up.
  • Who's Online   1 Member, 0 Anonymous, 568 Guests (See full list)
