Ok .59 inch X 25.4 = +15mm offset < That's should be quite tucked in and very safe on a 7'' rim.
To convert equivelents take 6 mm for every 1/2 inch rim width.
So, if you start with a 14 X 7 @15
Then the outside of 14 X 6.5 rim would be at the same relation to the fender lip @ +9
Appliance Industries again. They were called "Dia-mags" and were only available in 14x6 in four lug, as I recall. They used a really odd proprietary lug nut that would probably be a b**ch to find today.
