280master is correct, it is a worn ignition switch. Mine does it in any position and frankly I find it convenient like if you need to go back into the house but you started your car already, etc. Back in the day when you could buy a whole lock set from the dealer I replaced my wife's 240Z key set so all the keys were the same and the key doesn't come out.
https://www.classiczcars.com/topic/18863-is-it-normal/#findComment-155571
While not normal, this seems to be a common thing amongst Zs. I used to be able to not only pull the key out, I could also open up my friend's 280, he could open up mine, etc.
I had a good chuckle with the guy I bought my 240Z from when he mentioned that the car's locks didn't allow other Z owners to get into it!!! :geek:
https://www.classiczcars.com/topic/18863-is-it-normal/#findComment-155943
  • Who's Online   2 Members, 0 Anonymous, 1,505 Guests (See full list)
