ditto on the wheel bearing grease.
i had the grease fittings on 1 side and a plastic plug on the other side which i replaced with a grease fitting. shot it with the grease gun and all seems well.
never heard about the gl4 oil being used, i'd be interested to hear more.
https://www.classiczcars.com/topic/18894-240z-rack-lube/#findComment-155867
Thanks, I've got the hole on the LHs of rack which is pluged for grease I guess. Below the slack adj nut I have another small bolt, which I opened expecting oil to run out but it appears to be blocked with grease, from the manual you have to fill the rack by removing the slack nut etc.
On closer inspection it seems the LH inner tie rod is loose, can this be replaced or does it mean the whole rack refurb
https://www.classiczcars.com/topic/18894-240z-rack-lube/#findComment-155884
  • 18 years later...
Ok searched greasing the steering rack on the site, here we are.
73 240z, purchased a rebuilt steering rack ungreased. What is the procedure?  how do you know it's greased enough?
Single grease fitting under the steering shaft spline. Do I need to add a second grease fitting on the passenger side small bolt?
Thanks.
https://www.classiczcars.com/topic/18894-240z-rack-lube/#findComment-666822
All you can really do now is remove the rubber boot on the P/S, turn the steering wheel all the way to the right so that it is exposing as much of the P/S rack as possible and grease it up well. Turn the wheel all the way back and forth to spread the grease around and before you put the boot back on put some grease inside the boot.  It will be decades before it needs greasing again.
https://www.classiczcars.com/topic/18894-240z-rack-lube/#findComment-666834
P/S rack?
https://www.classiczcars.com/topic/18894-240z-rack-lube/#findComment-666854
  • Who's Online   0 Members, 1 Anonymous, 1,290 Guests (See full list)
