Site going down soon for upgrades ×
This is probably an easy one.
I am trying to remove my Amp/fuel guage. The temp. guage came out easy. All I had to do was un-plug the pigtail and light wire and it was off.
The fuel guage seems to have two additional leads connected to it. They are comming from a wire harness under the dash. Both have a right angle rubber nipple over them.
How do I get these off?
If I pry the rubber nipple back, I can see little brass nuts. Do I indo the nuts, or do these plugs simply pull off like the light does?
Thanks,
Mark
https://www.classiczcars.com/topic/19038-ampfuel-guage-removal-help/
