Site Updates this Weekend ×
I have a Datsun 260z with Hitachi carburetor thats 30 yrs old. I been shopping around, and triple carb are very expensive. I found a used one for a $1000 dollar. I don't know if this is worth the money spending on a carb. How much difference will it make on the car?..Can anyone tell me if this is worth it...
thanks,
Vissan
https://www.classiczcars.com/topic/19134-triple-weber-carburetor/
If your motor is otherwise stock, triple Webers are way too much carb. You need to be looking for something less radical. The most common swap would be a pair of '70-72 SUs, but other options to look at would be dual downdraft Webers or a Holley four barrel.
I am sure Arne knows more than me so this is just hearsay but I have heard others say to stay away from 4bbl carbs. FWIW
Hi Vissan:
Do you mean you found a used Weber, as in "one" 4 barrel? Or do you mean you found a used set of triple Webers, along with the linkage and manifold - for $1000.00.
If they are in good condition - and presently running on an L series engine - then yes, $1,000.00 would seem to be in the ball park for them. They can range from $500.00 to $1,200.00 depending on the completeness and condition of the set-up. Good chrome air cleaners for them are about $75.00 each as I recall... so add or subtract if they are included or not.
I have had lots of experience with triple Webers - I wouldn't recommend them today. I bought and installed mine back in the mid 70's... then spent twice as much as they cost new, on trying to get them properly tuned on my car. No, I wouldn't recommend them today...
That said, many people simply like the "look" of them on the Z Engine, and/or the sound of them at WOT...
Get a set of SU's off the 70-72 240-Z's, including the intake manifold, linkage and air cleaner. Then send the old SU's to "Z Therapy" as an exchange for a set of their Re-manufactured SU's. For about $750.00 you'll have a good running set up, that will supply all the air/fuel your L26 can call for.
If you want more of a "project".. or something not so common... opt for a Fuel Injection set-up. There are several alternatives to look at - just do some research on HybridZ.com.
Good luck,
Carl B.
Carl Beck
Clearwater, FL USA
http://ZHome.com
I've worked with all of them and this is my experience. The early SUs work well under all conditions. The triple Weber/Mikuni/OER work better for racing conditions. The dual Weber downdraft and Holley are okay substitutions for the SUs if you already have them.
As most have said, I believe you will be happiest with a set of well tuned Sus-buy a used set, send them to ZTherapy, and you will be all set-if you are handy, get the rebuilt/bearing kit, and rebuild them yourself.
Will
LOL I am also selling my SU's In a few weeks!!LOL
  • Who's Online   2 Members, 0 Anonymous, 957 Guests (See full list)
