pimp1911 Posted March 7, 2006 Share #1 Posted March 7, 2006 Has anybody every noticed normal holes(ie drilled holes) under the sound deadner. I chisled up all of the sound deadner in my car and noticed drilled holes under it. Link to comment https://www.classiczcars.com/topic/19142-holes-under-sound-deadner/ Share on other sites More sharing options...
MikeW Posted March 7, 2006 Share #2 Posted March 7, 2006 Can you post a picture? Link to comment https://www.classiczcars.com/topic/19142-holes-under-sound-deadner/#findComment-158485 Share on other sites More sharing options...
Mike Posted March 7, 2006 Share #3 Posted March 7, 2006 Where? In the floorpans? There are supposed to be two bigger holes (with plugs in them) on the floorpans.Anyway, let us know where you're talking about.... Link to comment https://www.classiczcars.com/topic/19142-holes-under-sound-deadner/#findComment-158488 Share on other sites More sharing options...
pimp1911 Posted March 7, 2006 Author Share #4 Posted March 7, 2006 Follow the screwdriver tip. These 2 holes where under the sound deadner center console. And the other 3 holes are around the rear tower. Link to comment https://www.classiczcars.com/topic/19142-holes-under-sound-deadner/#findComment-158495 Share on other sites More sharing options...
pimp1911 Posted March 7, 2006 Author Share #5 Posted March 7, 2006 Here is just a overall pic. Doing it the hard way. No dry ice.Hammer and chisel. Ouch. Link to comment https://www.classiczcars.com/topic/19142-holes-under-sound-deadner/#findComment-158498 Share on other sites More sharing options...
Tri-Star Posted March 7, 2006 Share #6 Posted March 7, 2006 thats how i did it. i wish i had found these fourms before starting work on my z. as for the rear holes 2 of them may be gor the tool box hienge, if not then no i didnt ahve any of those holes. Link to comment https://www.classiczcars.com/topic/19142-holes-under-sound-deadner/#findComment-158500 Share on other sites More sharing options...
ncz Posted March 7, 2006 Share #7 Posted March 7, 2006 No holes on the console, sorry man, plug them up. Looks like your having fun, it will we over soon. I was surprised to find surface rust way up under the tar paper where it held moisture. Glad I took it all off. Looks like you are too. Good luck Link to comment https://www.classiczcars.com/topic/19142-holes-under-sound-deadner/#findComment-158501 Share on other sites More sharing options...
pimp1911 Posted March 7, 2006 Author Share #8 Posted March 7, 2006 I was shocked too. I am determined to kill it all. Link to comment https://www.classiczcars.com/topic/19142-holes-under-sound-deadner/#findComment-158502 Share on other sites More sharing options...
EScanlon Posted March 7, 2006 Share #9 Posted March 7, 2006 The two rear ones actually look more like the holes for the Luggage Strap Hold Down. Not sure about the next one further back, unless it's for the Luggage Stop Bar. This was an aftermarket Chrome Bar that stopped your packages from sliding forward.The one on the hump looks like it could have been from the center console screw hole. Or from an "accessory" that someone mounted.E Link to comment https://www.classiczcars.com/topic/19142-holes-under-sound-deadner/#findComment-158504 Share on other sites More sharing options...
1 Bravo 6 Posted March 8, 2006 Share #10 Posted March 8, 2006 No holes in the hump in that position, I'd say fill 'em.Enrique,Do you still think those other holes would be for the luggage straps ??They look to be in the wrong spot for that.Hard to tell from the photo just where that area is. My guess is to the left of the spare wheel well.The holes wouldn't have been for a towbar mount would they ????That's my guess.Rick.:devious: :devious: Link to comment https://www.classiczcars.com/topic/19142-holes-under-sound-deadner/#findComment-158577 Share on other sites More sharing options...
pimp1911 Posted March 8, 2006 Author Share #11 Posted March 8, 2006 Correct they are to the left of the spare wheel well. Link to comment https://www.classiczcars.com/topic/19142-holes-under-sound-deadner/#findComment-158599 Share on other sites More sharing options...
ggarrard Posted March 8, 2006 Share #12 Posted March 8, 2006 Aren't the luggage strap holes threaded (ie - nut welded underneath the floor) - These holes look as though they aren't threaded, so I would guess they are "extras"...GWGarrard Link to comment https://www.classiczcars.com/topic/19142-holes-under-sound-deadner/#findComment-158611 Share on other sites More sharing options...
