Anyone know where i can get an L28ET - a factory turbo'd L28?
A friend has a 280zx with an L28E, they would really like to turbo it but dont wanna go through the hassle's and expense of building and assembling components from scratch, basically after a good running L28ET,
Is this possible in Australia?
https://www.classiczcars.com/topic/19337-l28et/
A quick scan of OZDAT classifieds found what you are after just go to the site below. I have no idea where in Aus you are, but this engine is being sold out of Wollongong by the add.
http://www.ozdat.com/classifieds/index.html
complete running hoted up package.
hope it is what you are after
cheers
Steve:classic:
https://www.classiczcars.com/topic/19337-l28et/#findComment-160719
heres the ad. Nixcars is a member here.
L28 TURBO ENGINE 4 SALE This engine was built by SWR & runs a P90 turbo head, T3 turbo, EFI manifold with 300ZX 55mm T/B, Wolf 3D ECU, FJ20 turbo injectors, electronic ignition, on 8psi boost & has only travelled 15,000 kms. Engine is still in the car (260Z), can hear it run & test drive.
Price: $4500ono Location: Wollongong NSW
Contact: Nick Email: nixcars@aapt.net.au
Phone: 0416 283 194 (hours: 9am-9pm)
Or you could get some L20 turbo parts and bolt them on the L28 if you want to do it cheaper
Heres a L20ET advert:
L20 6CYL TURBO factory turbo eng and stumpy 5speed gearbox . will split motor from box
Price: $950 Location: logan QLD
Contact: bevan Phone: 0412 578 474 (hours: 7am- 8pm)
https://www.classiczcars.com/topic/19337-l28et/#findComment-160720
