That square hole next to the hazard switch is where the radio antenna rocker switch is in my Ca. '75 280z. Except for the radio, my Z interior is the way it came from the dealer when new.
can u take a picture for me so i know what switchs to get?
my 77 has this center console....
http://www.classiczcars.com/photopost/showphoto.php?photo=19741
As far as where to get it from.....if you want a brand new one you could get it from Black Dragon Automotive....used to be british victoria...otherwise i get some of my parts from junkyards
Hi Matt,
I've attahced a photo of the antenna switch along with the other switches and warning lights above them. It appears the PO removed the part of the console that houses the lights.:( Maybe, if you cared too, you could replace that console with an unmolested one so you'll have the complete set-up.
Rob, I've noticed you have a fuel indicator above the hazard switch. Was there a console change in the 280's life? My 78 has the fuel lamp above the center heater vents, opposite what would be the floor temp warning lamp.
As for the 3rd hole, mine's plugged with what looks to be a factory plastic plate.
  • Who's Online   3 Members, 0 Anonymous, 1,470 Guests (See full list)
