I have a 79 280zx , and am changing from FI to triple weber 40 dcoe's setup. I have a motorsport header, and 2.5 in. custom exhaust system with magnaflow muffler, and am planning the following mods: Fidanza aluminum flywheel, act hdss clutch, motorsport stage 2 cam kit, carter fuel pump. I'm not sure which distributor, and electronic ignition I should buy. I was thinking either mallory or msd, does anyone have any suggestions on which one to buy? Any help would be appreciated. THANKS
https://www.classiczcars.com/topic/19358-msd-distributor-ignition/
Gee, here you have a '79 ZX distributor and you're thinking of getting rid of it? Many of the 240/260/280Z people on this site are hunting for that very unit!
Seriously, for what you are describing, the distributor you have now is probably fine. If you want a nice hot spark, you could piggy-back something like an MSD 6A. Probably no real benefit to replacing the distributor itself unless it's worn out.
  • Who's Online   2 Members, 0 Anonymous, 1,370 Guests (See full list)
