i have a 1978 280z with a 1982 drive train. when i put starting fluid in it,it will run off that. but i can't get the fuel injection to work at all. do i have to have a 82 ecu and harness to get it to work?? because i already have it and the 82 harness is totally different than the 78 as in hooking things up. which wires would i have to splice to get it to work, or is there some how i could still use my 78 harness and ecu??? please help
https://www.classiczcars.com/topic/19430-78z-with-82z-drive-train/
Assuming all of your pieces are good, using the 82 engine with the electronics and harness from the '78 should be almost plug and play-don't splice anything, but use the 78 afm.
I have an 82 turbo engine running on 77 electronics and harness-other than the idle control, making it work was not hard, but it was tedious and daunting.
Get the engine wiring diagrams for both years, and address the differences.
Will
I've done that swap. Your 82 L28 is nearly identical to the 78 L 28. Wire the 82 as though it were a 78 and it should work fine. If it will run on starting fluid then it sounds like a fuel starvation problem. Start checking fuel related items. Fuel pump, pressure regulator, filter, etc.
  • Who's Online   2 Members, 0 Anonymous, 605 Guests (See full list)
