Site going down soon for upgrades ×
Are those the 2 hoses that run up under the dash on the left hooked up to a diaphragm of some sort?I did replace those lines but have not checked the actuator if that is what the diaphragm is.I also checked the cable bottom left that works the lower doors which are ok. I guess a vacuume pump is in order.
https://www.classiczcars.com/topic/19478-77-heater/#findComment-162325
