so can the short nose R200 kaaz diff be used in a longnose? i did a quick search on the net (esp. in australia) and coldn't find any model numbers or suppliers
If it's any help Kent, the car Ben was driving at Bathurst, the KGC10, had a KAAZ R200 in it.The owner, Nathan Sawczak should be able to advise.
No they can't. They are two separate things.
They use a different pinion, but the carrier is the same. The 240SX unit that replaces the OPEN carrier has 12mm ring gear bolts, but you can use a spacer if you're worried about that, but it isn't absolutely necessary. The 240SX unit to replace a VLSD has the wrong spline count on the side gears, so it can't be used.
  • 5 months later...
  • Who's Online   1 Member, 0 Anonymous, 1,485 Guests (See full list)
