The mags that Fun-In-My-Z has shown look totally different than the ones that 26th-Z has pictured. Are the black ones what you are referring to as the "factory steel" and the Fun-In-My-Z just a dealer installed option?
Thanks,
James
Thanks,
James
"Fun In My Z" posted a link to a picture of a car with the black steel wheels which are hidden behind the Hubcaps that you see in that picture.
FWIW, the mags (actually aluminum wheels) on the car in the other picture "Fun in my Z" linked to are in fact on "26th Z"'s car. I don't see that "26th Z" posted any pics of mags.
There was also a 5.5"x14" aluminum Road Wheel listed in the early Parts Catalogs, but not FMVSS approved and if put on order - they would always be back-ordered...I tried every year for several years to order a set though our Parts Dept., ... but no luck.
FWIW,
Carl B.
Carl, do you have a picture of those? I'd be curious to see what they looked like.
The wheels on 26th in that picture are Japanese spun aluminum 14x6. They were the wheels originally installed by the dealer and they are commonly referred to as "Slots". The black and silver wheel I posted is the orignal steel wheel from 26th. The 'D' hubcaps I posted are actually the later version of the "D" hubcap. Notice on the back, the many closely spaced tabs for gripping the wheel. Earlier versions of this hub cap had less tabs and they were more widely spaced. They had a tendency to fall off.
And one comment about the slang being used: "Mag" is short for magnesium, a common material used for casting wheels - very light weight - and not the best of terms to use for commonly discssing wheels.
Now, the Japanese cars did not get "D" hubcaps because they were not Datsuns. They got this hubcap. The Japanese option wheel originally available was manufacured for Nissan by Kobe Seiko. Here is a racing version in magnesium. You will commonly see this optional wheel style (in aluminum) on the PS30 / Z432.
That Kobe Seiko wheel that you posted a picture of Chris, I believe is of an optional wheel for the "street version" Z432. However, I do believe that those were the narrower wheels used on the Works rally cars. Your picture is of the 14 by 6j and it was magnesium. The standard Z432 wheels were 14 by 5.5j, and they looked slightly different than the picture of the one that you posted. (Correct me if I am wrong, but I believe that picture is from an old Yahoo Japan auction. I wonder how much they sold for?)
I don't think you would commonly see aluminum Kobe Seiko reproductions on Z's in Japan, but I could be wrong as I have never been there. The aluminum wheels that you are referring to were reproduced by a company I am sure Alan knows of. I am not sure if Kobe Seiko ever made a wheel for the Z's in aluminum.
When I was talking with Matsuo-san, he told me that Kobe Seiko was an outside company that made wheels for Nissan. I wonder what other manufactures' Kobe Seiko made wheels for? Off the top of my head, I know of quite a few wheels that Kobe Seiko made for the S30 both on the street and track. Someday I would love to get a set for my car, but I am sure that a nice set of 14 by 7j works wheels would be worth more than my car. "I got a 260z for my Kobe Seiko wheels!" I will keep dreaming. Hahaha. Take care everyone. I really would love to learn more about these wheels and Kobe Seiko's history with Nissan and other companies(?). Maybe we should start a new thread.
Please correct any information that I have posted as I am not an authority on this.
-Ben :)
Really? I didn't know that US Datsun dealers sourced aftermarket "add-on" wheels from Japan. I thought that all of them were sourced locally. (in the USA). Which company made those Japanese spun aluminum wheel shown in the picture Bill posted?
Hold on, let's get this straightened up before it gets out of hand. The picture that you posted is of a Kobe Seiko 'Maglloy' wheel - which Kobe Seiko manufactured and sold to the general public as their own design from the mid 1970s. This was essentially the same pattern that they manufactured for Nissan ( used as standard equipment on the Fairlady Z432 ) but with some small detail alterations and some added lettering to differentiate it from the OEM Nissan items.
Kobe Seiko made a number of different wheel designs for Nissan to use on the S30-series Z:
*Original 432 wheel. Cast magnesium. Fixing points for a small centre cap. Also quoted as an 'Option' part for the S30 Fairlady Z-L and S30-S Fairlady Z. Manufacturing date was stamped onto each wheel, as magnesium was recognised as having a limited life expectancy for safe road use. Usually painted dull gunmetal colour.
( Chief Designer Yoshihiko Matsuo wanted all models of the S30-series Z to have 4-spoke alloy wheels, but this was overruled for reasons of cost - so only the 432 got them in the end ).
*Works 'Rally Mag' wheel. Cast magnesium. No centre cap fixing points, and 'vented' spoke castings. Manufactured in 6jj x 14 and ( more commonly used ) 7jj x 14. No manufacturing date stamps. Never sold to the general public, and supplied only to Nissan for their 'Works' rally cars. Usually painted dull gunmetal colour.
And then in the mid to late 1970s, after the above wheels were no longer being made for Nissan, Kobe Seiko dusted off the original design and made some modifications. They sold these wheels as:
*Kobe Seiko 'Maglloy' wheel. Cast magnesium ( some also later manufactured in aluminium ) and fully tested / licensed for use on road cars. Clip-on centre caps. Usually painted silver.
Private restoration companies have in the past recreated both the '432' mag and the Works 'Rally Mag' in limited editions ( made from aluminium for longer life ). These pop up from time to time to confuse matters - but the fact that they are aluminium and not magnesium usually indicates their status as replicas.
See pictures below for illustrations of the above three 'types' of Kobe Seiko wheel.
Trivia department: Kobe Seiko were active during the Pacific War years, and manufactured all sorts of castings and forging for the Japanese military. One of their specialities was wheel manufacture, and they made many of the magnesium wheels for Japanese army and navy aircraft - including those on the legendary Mitsubishi A6 'Zero Sen' fighter..........
Alan T.
Maybe they were "sourced" locally ( and from USA-based companies ), but I'll bet that more than half of the wheels sold in the USA by American companies during that period were actually manufactured in Japan - and many of them even designed there too. Japan was a wheel manufacturing powerhouse during that period.
No, actually I sold custom wheels for a living during part of the '70s, and imported wheels of any kind were VERY uncommon, and the few imports that were on the market here were almost exclusively expensive and European. As a purchasing agent, I visited most of the bigger name companies' production facilities - all here in the states.
You see, the obvious quality and production efficiencies of the Japanese not withstanding, the Japanese wheel makers couldn't compete in the commodity wheel market, because they were more regulated than the US aftermarket was in those days. The US-based companies were not required (at that time) to do much if any testing. So it was very easy to crank out cheap aluminum wheels at prices the Japanese makers could not compete with. Therefore 99% or more of the custom wheels fitted by either the dealers or by new owners were of US manufacture.
See the attached scan from the Road & Track comparison test of the 240Z, MGB GT, Opel GT and Triumph Spitfire. (About May, 1970, I think.)
Hi Arne:
Yieks.. how did I forget that!! Road & Track July of 71.
Now all we have to do is track that car down and see if the wheels are still on it!
thanks,
Carl B.
I'm surprised to hear this, Arne.
I grew up in the Sixties and Seventies looking over my dad's shoulder whilst he was reading magazines such as Motor Sport, Autosport and Motoring News, as well as very glamorous 'import' magazines such as 'Hot Rod', 'Popular Hot Rodding' and even 'Hop Up'. There was a period when I would have sold my soul for a set of Halibrands to go on my Thames panel truck ( dreaming that it would become a 'Gasser' ), but a set of Appliance 'dish mags' or Superior 'slot mags' were as close as I could get. I used to go to my local - and not so local - speed shops just to stand open-mouthed and watery-eyed in front of their selection of custom wheels. Many of these were from American companies, but even then I noted that a few of these were wearing 'Made In Japan' stickers on the inside rim....... This was so surprising to me that I made a mental note of it at the time. I also noted that the ones wearing those 'Made In Japan' stickers were often the cheaper designs ( and therefore more likely to be within my reach )......
I even remember ( after later getting into old Porsches and VWs ) that some of the early Empi wheels were made by BRM here in the UK, but were then farmed out to Japanese manufacturers who could make them more cheaply for the USA market.
Do you think it is possible that some of the USA wheel manufacturers were having some of their wheels manufactured ( or part-manufactured ) in Japan, and then finishing / re-packaging them as a 'Made In USA' product? I'm talking about the 1970s here.
The wheel aftermarket in Japan became absolutely HUGE through the mid-Seventies and the Eighties. The array of manufacturers, 'design' and 'character' brands and 'tie-ups' with known brands ( such as March for instance ) was mind boggling. Look through a 1970s Japanese car magazine such as Auto Technic or Car Graphic and you would see what seemed like at least half of the magazine consisting of flashy advertisements for aftermarket wheels.
I find it hard to believe that this did not spill over into the USA market.
Alan T.
Hi Stephen:
I don't believe I've ever seen a picture of them.
There is a 5.5"x14" Road Wheel- Aluminium listed in the Parts Catalog as:
40300-N3225 with a drawing of an aluminium wheel, but that drawing shows cars up through 78...
Maybe Chris can check an earlier copy of the parts catalog and see if it's the same..
FWIW
Carl B.
  • Who's Online   0 Members, 0 Anonymous, 1,544 Guests (See full list)
