Aussie260z Posted April 24, 2006 Share #1 Posted April 24, 2006 HELP!!!Where can i get a 1982 280zx Ignition coil in Australia,Repco, Super-cheap even the Nissan Dealership cant get me one, the Dealership has a listing for the coil, but its $185AUD,Got to be able to get one of these locally at a reasonable price, i've tried Warren at allzparts and he had a used one for me, but nothing eles,Anyone know where i can get one? Link to comment https://www.classiczcars.com/topic/19755-280zx-ignition-coil/ Share on other sites More sharing options...
=Enigma= Posted April 24, 2006 Share #2 Posted April 24, 2006 Is there something special about the 280ZX coil or are you go for authenticity? If not just go grab an MSD or a Pertronix Flame Thrower coil and be done with it. Link to comment https://www.classiczcars.com/topic/19755-280zx-ignition-coil/#findComment-164817 Share on other sites More sharing options...
Zedrally Posted April 24, 2006 Share #3 Posted April 24, 2006 In the quest for further info, can anyone tell me if there is any difference between coils at all. I know that some have a built in resistor, but is there really any difference? Link to comment https://www.classiczcars.com/topic/19755-280zx-ignition-coil/#findComment-164819 Share on other sites More sharing options...
260Zed Posted April 24, 2006 Share #4 Posted April 24, 2006 When I replaced mine I also had trouble finding one through the normal suppliers. I ended up contacting Bosch and they found me one througha wholesale supplier;Brisco Butler Automotive Services07 3857 3011Part # BIC290Only cost me $30, BargainHope it helpsLuke Link to comment https://www.classiczcars.com/topic/19755-280zx-ignition-coil/#findComment-164825 Share on other sites More sharing options...
Aussie260z Posted April 25, 2006 Author Share #5 Posted April 25, 2006 Enigma, no dont care at all, just want to get a new coil and not pay $185 for it!!!With those coil's do i have to do anything eles or will it bolt straight up?260zed, thanks for that mate, your a legend, I wonder why no one lists the 280zx coil? Link to comment https://www.classiczcars.com/topic/19755-280zx-ignition-coil/#findComment-164916 Share on other sites More sharing options...
=Enigma= Posted April 25, 2006 Share #6 Posted April 25, 2006 It's a fairly standard part. Just go to any parts store and have them look up a replacement. If not, you can always grab one from the junk yard out of a car with electronic ignition. When I converted my original 240Z dizzy to a 280ZX dizzy, I grabbed a coil and bracket from a 1980 Datsun B210 with elec ignition. It cost me $3 and worked like a charm. Someone who understands and can articulate the differences between coils designed for points vs. elec ignitions should probably chime in here. As I understand it the difference is basically in the amount of resistance, with the elec ign coils and high performance coils having less resistance. Supposedly this can be a problem in a points based system for reason I don't fully understand, and a desired thing in a high perf application. Link to comment https://www.classiczcars.com/topic/19755-280zx-ignition-coil/#findComment-164953 Share on other sites More sharing options...
datfreak Posted May 14, 2006 Share #7 Posted May 14, 2006 When I replaced mine I also had trouble finding one through the normal suppliers. I ended up contacting Bosch and they found me one througha wholesale supplier;Brisco Butler Automotive Services07 3857 3011Part # BIC290Only cost me $30, BargainHope it helpsLukeluke,thank you so so much...you just saved me $ ! Link to comment https://www.classiczcars.com/topic/19755-280zx-ignition-coil/#findComment-167467 Share on other sites More sharing options...
Roujin Posted October 29, 2006 Share #8 Posted October 29, 2006 I got a Bosch igition coil from Repco in geelong for $48 in Geelong last week if they are charging ^$100 id tell them to get bent Link to comment https://www.classiczcars.com/topic/19755-280zx-ignition-coil/#findComment-187540 Share on other sites More sharing options...
RogerZ Posted October 29, 2006 Share #9 Posted October 29, 2006 You didn't say whether the car was a turbo or not. The turbo coils are much different than the n/a coils. The n/a coils are readily available but the turbo coils have an ignition module in conjunction with them and that is the spendy part. Link to comment https://www.classiczcars.com/topic/19755-280zx-ignition-coil/#findComment-187562 Share on other sites More sharing options...
Victor Laury Posted October 29, 2006 Share #10 Posted October 29, 2006 If you've done the EI conversion, you need a low ohm, 12volt coil like the ZX (fat) coil to use without the ballast resistor.However there are cheaper alternative - you buy a coil for a 1980 310 (210), it also used the EI dizzy, the coil meets the same specs, it's the same diameter as the stock coil and is much cheaper. Link to comment https://www.classiczcars.com/topic/19755-280zx-ignition-coil/#findComment-187591 Share on other sites More sharing options...
