I bought a triple weber setup locally off of a wrecked 280z,and the linkage rod is bent up, and I think two plastic bushings are missing that keep the linkage tight. I was trying to find out what type of manifold it is so I can get new linkage parts. On the bottom ,there is the number 0030 stamped into the casting. Also , instead of having the bolt type linkage guides, it has two uprights cast into the aluminum. Any help would be appreciated.
I measured the carb side of the manifold and the openings are about 42mm. The linkage rod measures 3/8" , and the two holes where the linkage goes through are 1/2". There were plastic bushings that made the linkage tight and acted as a bearing, but they were cracked. Do you know any place where I can get parts like this? THANKS
Sounds like something that would be easy to replicate with a lathe. Maybe an oiled bronze bushing instead of plastic.
42mm... Weber makes a 42mm carb I think, but it's kind of an oddball. You could port the manifold out to fit 44's or 45's.
The carbs I have are Weber 40 dcoe 151 series. These were on the manifold when I bought it. The setup was on a running 280z owned by a friend of whom I bought them from. According to him, the guy was on a back road in PA, and hit a hump going 130, and flipped the z on it's roof in a corn field. The driver's buddy got hurt pretty bad, and the driver went to jail, so he sold the kit to this guy cheap. I got the setup for $200, everything is in good shape except the linkage.
Well the fact that the carb opening is smaller than the manifold is preferable when compared to the manifold opening being smaller than the carb opening. It should work just fine. I'd be surprised if you couldn't find that bushing readily available, but if you did have to have it made it should be really easy for any machine shop to make you one. Looks like a nice manifold all in all!
  • Who's Online   0 Members, 0 Anonymous, 1,451 Guests (See full list)
