I have the defogger switch plugged into the correct connector. Here is the problem... When I plug the console switch into the wiring harness, the small red wire that goes from the connector to the bayonnete connector is grounded. This means the blower switch will also be grounded and burn out the fuze. If I disconnect the red wire, the blower switch works great. What do I have here? Why is the red wire grounded?
  • 8 years later...
