Swapping a early 260Z, 1974 from the flatt toppers to the round top 4 screw I believe, A friend suggested this since my org carbs are dying, So i bought some 240z round tops, but no manifold and linkage, what should I do, is the linkage similar to the 260? at glance i didnt see a match, Im worried,
thanks guys!!!!!!! :bunny:
https://www.classiczcars.com/topic/19955-quick-question/
The intake on the 260 engine is a good one. You will need the insulators that fit between the carbs and the intake. The ones for the round tops are much thicker. The linkage that fits between the round tops is a different length the flat top length and will not work. You will also need the air cleaner so you can connect the various hoses . Like the over flow lines from the float bowls and the clean air supply line that goes to the fuel tank . The 260 air cleaner is different and can only work if you get some kind of adapter . I think Ztherapy sells them . Where are you , in the USA ? Gary
https://www.classiczcars.com/topic/19955-quick-question/#findComment-166587
Robby, have faith, you are headed in the right direction with the round tops. As Beandip mentioned....you'll need the thicker insulators (and gaskets of course) between the SU's and the manifold. Regarding the linkage, shop around and you will find what you're looking for. If you don't want to scrounge up OEM air cleaners, there is always aftermarket units. Also, I'm not clear if the 260 choke cables will swap to the round tops but, its a good chance they do.
https://www.classiczcars.com/topic/19955-quick-question/#findComment-166820
Thanks man, I just figured round tops would be a better way to go, org. i wanted to go side draft webers, but tuning, base price will kill my wallet,
ya thanks 240zx, Ill have to i guess just collect some parts here and there and see if i can peice it together, let me know if you have any leads on on linkage :)
thanks again
_RoBBy
https://www.classiczcars.com/topic/19955-quick-question/#findComment-166849
thanks again
_RoBBy
Robby, regarding the linkage....start looking at PIC-A-PART yards or call Victoria British and ask if they have the linkage items. There are more suppliers that likely have the parts but I'm not recalling any others at the moment. And there is always the internet....best search tools I've ever used.
Tom
https://www.classiczcars.com/topic/19955-quick-question/#findComment-166860
  • 1 month later...
