26th-Z Posted May 10, 2006 Share #13 Posted May 10, 2006 Who said anything about getting angry? Link to comment https://www.classiczcars.com/topic/20000-numbers-matching-series-i-early-1970/?page=2#findComment-167054 Share on other sites More sharing options...
Arne Posted May 10, 2006 Share #14 Posted May 10, 2006 Who said anything about getting angry?No one, I guess. To me the term "bitch him out" implies some anger, or at least be a bit demanding, but I'm sure you didn't mean it that way, Chris. Different idioms in different parts of the country, perhaps. Link to comment https://www.classiczcars.com/topic/20000-numbers-matching-series-i-early-1970/?page=2#findComment-167057 Share on other sites More sharing options...
er34gtt2000jp Posted May 11, 2006 Author Share #15 Posted May 11, 2006 Ok, I made it back home in one piece. No where near the trip that I took to New Mexico to get me 73' but it was a good hour drive there. The car needs help, but overall it is really solid! I didn't get any keys with it and the ignition had been removed so the car could be moved. So when I got home I pulled the dead battery and swiped the ignition switch from my 77' parts car, hooked it up and.....IT RUNS!!! Really good too! Sounds great and doesn't smoke. Revs really quickly and has a throaty burbley tone to the exhaust. Now the clutch doesn't work and the brakes are gone but it runs well! As for originality and completeness, it is OK......has Series II dash and gauges that don't work. Everything else seems to be original Series I, right down to the aircraft style seat belt buckles and round chrome coat hanger, seat too. Engine SN matches the data plate under the hood but it does have a 5 speed installed vice the original 4 speed. Original color was a yellow-green color. I guess it was gold, I will check the paint code later again. Couldn't really make it out before. Well here are a few pics, sorry for the poor quality. I had already put her to bed in the garage when I took them. I think with a few $$ put into here she will be back on the road in no time. I will sport her around town even with the munched fender! Link to comment https://www.classiczcars.com/topic/20000-numbers-matching-series-i-early-1970/?page=2#findComment-167104 Share on other sites More sharing options...
er34gtt2000jp Posted May 11, 2006 Author Share #16 Posted May 11, 2006 On a side note, anyone know how to get the hatch open without a key? Link to comment https://www.classiczcars.com/topic/20000-numbers-matching-series-i-early-1970/?page=2#findComment-167107 Share on other sites More sharing options...
hls30.com Posted May 11, 2006 Share #17 Posted May 11, 2006 Open the trim panel from the inside, and it is pretty easy. Just try any z key you have, if the lock is worn, it will probably work.Will Link to comment https://www.classiczcars.com/topic/20000-numbers-matching-series-i-early-1970/?page=2#findComment-167108 Share on other sites More sharing options...
er34gtt2000jp Posted May 11, 2006 Author Share #18 Posted May 11, 2006 Already tried the fresh new key from my 77' parts car, no joy. I think the keys are different, the 70' has a one-sided key it looks like. I will try to squeeze back there and pull the panel. The seats don’t fold forward and I am a pretty big guy so it is going to be a challenge. Thanks for the advice. Link to comment https://www.classiczcars.com/topic/20000-numbers-matching-series-i-early-1970/?page=2#findComment-167109 Share on other sites More sharing options...
hls30.com Posted May 11, 2006 Share #19 Posted May 11, 2006 There were several different keys, but a worn lock isn't usually picky!Will Link to comment https://www.classiczcars.com/topic/20000-numbers-matching-series-i-early-1970/?page=2#findComment-167110 Share on other sites More sharing options...
er34gtt2000jp Posted May 11, 2006 Author Share #20 Posted May 11, 2006 Just a little update,My production date is 3/70 and my vin is 2562.According to the Z register there is a guy in Arizona that has 2563! Link to comment https://www.classiczcars.com/topic/20000-numbers-matching-series-i-early-1970/?page=2#findComment-167154 Share on other sites More sharing options...
Arne Posted May 11, 2006 Share #21 Posted May 11, 2006 Looks good! Wrong valve cover, but still, pretty complete.As for keys, the Series one cars had separate single-sided keys for the ignition and everything else. A bigger flag-shaped key for the ignition, and a small key for the doors/hatch/glovebox. Link to comment https://www.classiczcars.com/topic/20000-numbers-matching-series-i-early-1970/?page=2#findComment-167168 Share on other sites More sharing options...
sakijo Posted May 11, 2006 Share #22 Posted May 11, 2006 On a side note, anyone know how to get the hatch open without a key?A good locksmith can make you a key. Might be a little expensive, though. Link to comment https://www.classiczcars.com/topic/20000-numbers-matching-series-i-early-1970/?page=2#findComment-167217 Share on other sites More sharing options...
pimp1911 Posted May 12, 2006 Share #23 Posted May 12, 2006 Good save. Link to comment https://www.classiczcars.com/topic/20000-numbers-matching-series-i-early-1970/?page=2#findComment-167239 Share on other sites More sharing options...
26th-Z Posted May 12, 2006 Share #24 Posted May 12, 2006 Ah...the key discussion. Do a search in the archives! Here is what is stock for your car. The silver egg lobe shaped keys are ignition and they come in two different lengths depending on which side of Mt Fugi the sun was on when the ignition was installed. There are three different types of door and deck lid keys. One key should fit the door, deck, and glove box - and again - your car got whatever was being installed that day. Link to comment https://www.classiczcars.com/topic/20000-numbers-matching-series-i-early-1970/?page=2#findComment-167249 Share on other sites More sharing options...
