went and pulled a door latch out of a wrecked car for my 77 and will i was at it noticed the window had no scratches so decided to take it also, came right out after removing the 2 bolts with the rubber washers that go thru the glass.
tear mine apart and replace the latch and try to get the window out---NOT!
Pulled same 2 bolts and the damn thing WILL NOT come out. seems like it is bonded some how to the metal track it sits in. Am I missing something here guys?
https://www.classiczcars.com/topic/20023-door-window-removal/
Some of the parts must have been already removed from the junkyard car or the glass wouldn't have come out that easy. The procedure (in the FSM) for removing the door glass is more complicated than that. Haven't done it for years but I recall it involving much more than removing those two bolts.
