cremmenga Posted May 19, 2006 Share #13 Posted May 19, 2006 ha ha funny this topic should come up.. On my what is now parts car I started to sand on the rear fenders and all I was getting was bondo after ALOT of sanding I got made and took the big arse die grinder to it, it turned out that the wheel arches had been totally cut out and replaced with just bondo. There was no metal at all for wheel arches just bondo on top of bondo on top of bondo. In some places there was over an inch of bondo. talk about a kick in the head!!! and the guy I bought it from said it was a solid car. LIAR!!! little did he know that car that I bought for $400, well I sold the carbs alone and got that, ha, i'm temped to call him and tell him that!!! Link to comment https://www.classiczcars.com/topic/20073-bondomobile/?page=2#findComment-167966 Share on other sites More sharing options...
agemeansnothing Posted May 19, 2006 Author Share #14 Posted May 19, 2006 So due to the damage on my quarterpanel and door should I just replace them or what. Ian Link to comment https://www.classiczcars.com/topic/20073-bondomobile/?page=2#findComment-167974 Share on other sites More sharing options...
cremmenga Posted May 19, 2006 Share #15 Posted May 19, 2006 So due to the damage on my quarterpanel and door should I just replace them or what. IanI would!!! thats what I ended up deciding. I replaced both rear fenders, quarters, rockers, floors, and front frame rails. I figured if I'm doing it i might as well do it right and not worry about it then! Link to comment https://www.classiczcars.com/topic/20073-bondomobile/?page=2#findComment-167988 Share on other sites More sharing options...
Fun_in_my_z Posted May 19, 2006 Share #16 Posted May 19, 2006 Bondo is only temporary Ian. It will fall off Link to comment https://www.classiczcars.com/topic/20073-bondomobile/?page=2#findComment-167998 Share on other sites More sharing options...
zeewhiz Posted May 19, 2006 Share #17 Posted May 19, 2006 id just like to get my rust fixed.......... Link to comment https://www.classiczcars.com/topic/20073-bondomobile/?page=2#findComment-168041 Share on other sites More sharing options...
agemeansnothing Posted May 19, 2006 Author Share #18 Posted May 19, 2006 Yeah good point not just cover it over again....... any where you know of that has a piece from the molding strip all the way down? Link to comment https://www.classiczcars.com/topic/20073-bondomobile/?page=2#findComment-168072 Share on other sites More sharing options...
a7dz Posted May 20, 2006 Share #19 Posted May 20, 2006 Bondo is only temporary Ian. It will fall offI don't call thirty years temporary. But, this product like all others has to be used as it was designed. It can not be used as a metal replacement. There must be a backing for it. It also has to be completely sealed from all moisture sources. id just like to get my rust fixedI think we are all here at some point. Link to comment https://www.classiczcars.com/topic/20073-bondomobile/?page=2#findComment-168077 Share on other sites More sharing options...
