Thanks to all for help with last week's seat cover questions. Re-using the wire bead for the seat bottoms worked just fine...
Is the passenger side seat designed to not go back as far as the driver's side seat? There's not as much travel in the slide with the lever, in mine -- passenger side vs. driver's side. That is, the teeth can't go into as many rear-ward holes. Although even on the driver's side, travel is limited and some rear holes don't get used.
I've got a slide from a '76 where there's no limit to the travel and all holes get used.
Anyway -- I can't tell if this passenger-side slide is not working right, or if it's designed that way.
Thanks for any help.
Steve.
https://www.classiczcars.com/topic/20135-passenger-side-seat-in-73/
  • Who's Online   2 Members, 0 Anonymous, 1,503 Guests (See full list)
