Hey folks, can somebody help me out?
Earlier today as I was working inside the wheel-wells replacing my bumper ends I noticed that someone (probably the crazy 2nd P/O) had completely, cleanly, "snipped" all of the wires from the yellow side-marker lights on the front-end of my car.
Can somebody please find me the correct diagram for this and/or tell me where everything should connect to?...
Oh, and it might be helpful to know what gauge wire to use. Thanks!
https://www.classiczcars.com/topic/20173-side-marker-wiring-argh/
not sure on the 280Z but it's usually like this...
Black is ground
Green w/ white stripe is parking lights
Green/red is turn signal
If there are three wires, one is ALWAYS a ground. One is parking light (turn on the parking light and find that wire. You get the idea.
Wiring is pretty damn basic, even in a 76'. Just use the "process of elimination"
Hope that helps,
Dave.
Thanks for the help Dave, Zak.
Part of my question also has to do with the function of those fender-signal lights... are they identical in function to the turn-signals that face front?
I just want to make sure that when I get 'em wired up I know they're working correctly.
No, they are the same as the parking lights. They do not flash with the turn signals. (At least, not as wired by the factory.)
  • Who's Online   2 Members, 0 Anonymous, 1,393 Guests (See full list)
